On my 1996 STS the the radiator cooling fans work but do not turn on until the engine gets too warm. Is there a way of adjusting the temperature sensor so it will turn on the fans sooner and keep the engine cooler? Please let me know. thanks.
1999 White Diamond ETC
Turning on the A/C will keep the engine cooler because both fans come on.
2009 CTS4 2007 STS
to my understanding the cooling fans don't come on until the temp is 220 plus I'm thinking this is normal because my 97 sts does the same thing with no overheating problems.
open the hood and look at your fans. When you turn on the A/C the right (passenger) fan turns on automatically. When the A/C is off, the fan does not run unless the car is running hot.
2010 DTS
Why do you want to override it. Let the engine run at the tempurature it was designed to run at. Sounds like yours is operating as designed.
To answer your question, no, there is no way to adjust the sensor.
