I recieved my water pump tool today.Looks like simple proceedure put the tool and use a 1/2 inch breaker bar,but it wont budge its real tight.Did any one succefully did this kind of work?Do I have to use an impact or just brute force?
Help...The Instruction said clockwise to remove and I carefully looked at the impeller and it looks like clockwise to remove.
2005 CTS-V, 1994 Infiniti Q45
Well id use brute force..... maybe get an even longer breaker bar.....
1993 STS and 2004 DTS
I have replaced two of the Northstar water pumps.
Each time, I have had to use a 1/2" breaker bar with 24" of cheater pipe to break them loose.
Rotate clockwise to remove.
Be careful when it pops loose it is quick.
Clean the O-ring recess very carefully; I used a slim screwdriver then followed with a small brass brush for the general area.
I also wiped the O-ring with a little dielectric grease, so the pump would easily tighten back in place.
-George
Discussion Starter · #4 ·
George,
Thanks for the reply it is nice to hear from someone who realy have done this job,I will look for a bigger pipe that I can use to extend my breaker bar.Did you use the Astropnumatic tool or the more expensive shceley tool?
