Hello,
While doing my timing cover gasket on my beloved 1992 Coupe de Ville, I noticed that my timing chain was stretched. I ordered a Cloyes timing set, easy. But, when I read the procedure in the FSM, it tells me I have to remove the cam sprocket thrust button to get the cam sprocket bolt and discard it. Then, when reassembling it, it wants me to replace it with a new one. That wouldn't be a big problem if it weren't for the fact that I called 3 dealers who confirm that part isn't available anywhere (part # 01637031). There doesn't seem to be any aftermarket ones on RockAuto or anything, either! 🤷♂️
Is there any harm in reusing the old one? Is there maybe some aftermarket/generic solution to this?
Most importantly, if I were to reuse this one, how do I get it off without damaging it? I'm sorta new to tinkering with the actual guts of my engine, so I appreciate your patience.
By the way, the car has 118,000 miles, just for the record.
