1 - 11 of 11 Posts
bought a n 04 v . will be changing to ds3 regular tires. my car has no spare or jack what do i do?? can of fix a flat and 2 more years of road sid assistance??? buy a mini spare and jack any suggestions and WHERE to buy . thanxxxx
2017 Camaro ZL1; 2011 CTS-V sedan; 2004 Lightning
I'm carrying fix-a-flat and a prayer. But a full-sized spare will fit if you don't mind the extra weight and aren't using the tub for storage/subwoofer/gun collection.
benjet said:
I was under the impresion Roadside Assistance was for the life of the car.
At a price, sure. It's not free once you're out of warranty. Neither are failures deriving from aftermarket components. I found out the hard way when I called for help after a battery failure on my '03 CTS; they showed up promptly to tell me it wasn't original to the car and thus wasn't covered. I declined the $150 estimate and headed to AutoZone instead.
I bought a spare OEM rim from an on-line dealer, TPS and jack parts from GMPartsdirect, and 5 new Avon A/S from Tirerack and still saved money over buying 4 F1s or an EMT snow tire. The bumps from going over expansion joints also disappeared.
2004 CTSV
mlg
After injecting fix a flat latex in your flat tire, you can kiss the TPS good bye. That may be okay if you disable the interlocks that limit speed when there is no tps reading.
Ain't no quick way out.
Tony
1 - 11 of 11 Posts
