2001 SLS
So i just recently installed a sub and amp in my 01 SLS w/ BOSE everything works and sound great still have the factory Head Unit. Now from what i read all the speakers are powered by the factory amp my question is i want to next upgrade all 4 of my door speakers front and rear with aftermarket speakers will the factory bose amp be amp to handle 4 aftermarket speaker i don't want them to be under powered and sound bad. my plan is to just wire them all up to where the factory speakers were
EDIT: Ok so from what i read with the 01 seville w/bose the front speaker is a 5.25 and the new aftermarket speaker MUST be 2 Ohms to be compatibale with the stock bose amp.
so what size is the rear speaker and is that a 2 Ohm as well?
All speakers 2 ohm. 6x9 in rear i believe. There is a post here with specs on speakers for a bunch of years. The BOSE speakers have a small amp on each speaker IIRC.
2001 SLS
the 98+ had just the one amp that powered all 8 speakers i found a few post with the spec but they all had different anwser some say the BOSE in the front are 5.25 some same 8 so i just gave up i'll just leave it as is thanks for the reply
Several different sound systems in these cars and each one of them takes special requirements when doing modifications: The head unit is part of the car's content theft, TheftLock and serial data systems. Do something wrong and you have electrical problems, chime loss, steering wheel button problems and - worst case - a car that will not start.
