I had the Full BMR suspension parts under my car so the wheel hop wasn't an issue anymore. I bring the air pressure in the rear down to 18-20 psi on the F1's and I do heat them up a little. I really heat them up more than I should but I like to put on a show.. haha
Now I am running BFG drag radials and I run them between 16-18 psi and I still heat them up to much, back to that putting on a show thing..
I did crack my differential, not sure if it was on the track or if I did it on the street. I had it replaced under warranty and had the GM anti-wheelhop bushings installed and the BMR parts (well half of them) BMR Pinion support and the BMR wheel hop kit were removed for now. I am still running the BMR toe-rods and trailing arms though. I will be going back to the track, I hope this coming Friday to try it out with the GM bushings and I hope she still has no hop. The biggest thing you want to do, is if you do start to get hop, let off, wheel hop is a killer on the drivetrain..
Here are a couple videos so you can see there is no hop..
Bill
On F1's doing a 2nd gear strip..
http://www.cadillacfaq.com/faq/video/hdmlniumf1.html
On Drag radials running a 12.91 at 109.34
http://www.nitro-nights.com/2005v/HDMLNIUM_Drag_19august2005.wmv
