2007 Cadillac STS-V Black On Black
Alright guys so today I just took a look in the engine see if all my oil levels were ok and I noticed my steering and brake levels almost low. My question is would and break and steering fluid work or do i need a special brand?
Use DOT 3 or higher brake fluid from a new, unopened container. Brake fluid simply LOVES moisture, so if you use some from an old, opened container you run a very great risk of contaminating the whole system
Use a P/S fluid spec'd for GM units. Read the label
When all else fails, both specs are in the owner's manual.
Have your brake and P/S fluid changed EVERY 3 YEARS. GM dealer. Don't let Oil Doodle do the job - please.
Alright thanks for the info! Unfortunately I dont have the owner's manual but i'll bring it to my nearest GM dealer for the P/S.
