1 - 12 of 12 Posts
i want to add just the front v-bumper on my cts if i just add that will it be lower then the rest of the car or even still w/o the other pieces of the kit. i have to v grill on my car already so i assume the fits with the v-bumper and where do u get the bottom grill 4 the v-bumper.where can i get this from and what parts do i need to make it fit
CTS-V Front End Modification
Explanation: Installation of the CTS-V front bumper cover, fog lights (with brake vents), and grille(s) on a regular CTS.
Parts Needed:
12335777 Front Bumper Cover, CTS-V (must be painted)
25750634 Right Bumper Extension (new inner fender well cover)
25750635 Left Bumper Extension
25753700 Right Fog Lamp (includes air vent for brakes)
25753699 Left Fog Lamp
25752695 Lower Air Deflector (the lower engine cover/deflector)
25750638 Lower Stainless Mess Grille
15147586 Upper Stainless Mess Grille (includes emblems) - OPTIONAL (you can use the regular grille)
NA Two additional screws for the fog lamps (the regular CTS only uses two screws for each fog lamp, and the CTS-V front end uses three per lamp)
NA 10 Push-in expansion pins for lower grille​
Install Time: Approx. 3 hours
Approx. Cost: $1225 - $1500 (assuming parts through gmpartsdirect.com)
www.cadillacfaq.com is a great site for information on your cts. You might also want to try the search feature on the forum as we have one of these threads about once a week. Here is last weeks: http://www.cadillacforums.com/forums/showthread.php?t=48518
Enjoy.
Black the Darkside
Parts Needed:
Enjoy.
With paint you're up to $2,000. Excluding side skirts.
At it's lowest point, its exactly the same height as the stock CTS bumper. Where it differs is in the lip at the front, which sticks out a few more inches. Where the CTS bumper curves under, the V one curves forward. So if you have issues with speed bumps or steep driveways, it will affect the approach angle, but no more than the stock rubber air dam underneith. If you don't scrape that, you won't scrape the V bumper.
The side skirts are similar. They aren't any lower, but go straight down, where the stock CTS ones curve under the car. They're the same height to the ground. The rear bumper is the same story. It curves down and under (about 45 degrees) right at the bumper cover, where the CTS goes horizontal then dips 45 degrees undernieth at the spare tire well.
2002 Cadillac Escalade, 2006 Cadillac CTS
Parts Needed:
Enjoy.
I understand that the upper stainless mesh grill fits the regular CTS, you simply swap them... but will the lower mesh grill fit the regular CTS bumper?
2014 Cadillac CTS VSport
No, They are not even close in size. Look at a picture of both and you will clearly see why it would not fit.
I slammed my CTS into a large wooden post last night and cracked the front bumper (prior to drinking on St Pat's Day, if you can believe that). I want to take the opportunity to upgrade to the CTS-V bumper/grill.
Some questions - are the part numbers you list good for a 2004 CTS?
Since I hit the bumper going 10mph, are there some other parts under the bumper that might need replacement? If so, do you know the part numbers?? On the same note, are there springs that might have been damaged?
I'm pretty mechanically inclined - is this something that's pretty easy to do or would you suggest taking it to a shop?
Thanks for your time..
1 - 12 of 12 Posts
