2000 ETC
1959 Sedan DeVille 1966 Factory Formal Limousine 1967 Fleetwood Brougham 1968 Fleetwood Brougham 196
I will give this one more shot. "Theft System Problem", these is power to scanner. There is "Information" lights up. Can not pull codes through scanner or through climate control. I know how to pull codes. It is not letting me pull codes Anybody, anybody? For sale cheap in Kansa
585692
585693
585694
585695
585696
s City
I will give this one more shot. "Theft System Problem", these is power to scanner. There is "Information" lights up. Can not pull codes through scanner or through climate control. I know how to pull codes. It is not letting me pull codes Anybody, anybody? For sale cheap in Kansa View attachment 585692 View attachment 585693 View attachment 585694 View attachment 585695 View attachment 585696 s City
is that the CORRECT value resistor? it MUST match the chip on the key - EXACTLY -
try turning the ignition OFF -
disconnect the resistor -
and turn the ignition ON -
THEN try to pull codes -
the VATS should only kick in during the START phase - when activated -
UNLESS you have some aftermarket radio stuff -
if that doesn't work -
try disconnecting BOTH battery cables and touch them together for 5 seconds -
2000 Deville DHS
Do you experience any actual problems or symptoms related to that message on the DIC?
I’ve got the same message on my DIC upon startup more than half the time, along with the Security light that stays on when the car is running. I get codes:
B 1009: EEPROM checksum error
B 2734: Coded key controller memory failure
From the research I’ve done along with not experiencing any actual symptoms points to it basically being a false alarm that triggers that message and lights to come on.
2000 ETC
I tried the first one.pull resistor then try..... Correct resistor 4.75 k ohns (#11)
2000 ETC
If I turn on the ignition just to "on" and NOT TO START. Slowly the display comes up and says "Starting Disabeled" You don't have to turn it all the way to start. I have not tried grounding the positive side. I will do that right now.
2000 ETC
No security lights ever come on and no mods to any system (radio).
