Project thread for "Cadzilla"
7.6K views 70 replies 12 participants last post by  dodgetruck2
Just picked this up 1980 Sedan Deville 5.7 Diesel my friend who I got it from, deamed it Cadzilla so I figured I'd carry it on for him
My pictures are kinda crappy so ill get some new ones in the morning.
Top of the list right now:
Power Steering pump
Climate control center functioning properly
radio working better (has aftermarket alpine deck w/ 6 disk changer in the glove box, still have the factory am/8track player)
interior lighting
right blinker
windshield wipers
suspension
exhaust
on list for repair/parts
rear bumper
vinyl pieces between lights and bumpers in all 4 corners
fix rust/paint
windshield chrome
redo door panels
shampoo seats/carpet
cruise
factory style rim
side mirror with thermometer
trunk springs
I'm half tempted to shoot the vinyl with some black and see how it looks, redoing could be quite spendy. Going to be a long slow process but hope she turns out in the end, really hard on the budget trying to build two performance diesels and restore a car.
First question,
What do you call these pieces, 3 of 4 corners are broke and im trying to hunt down new ones
Run down of the basic problems i need to fix ASAP
Wipers - dont work, he has a switch for me just need to get it swapped out and hope thats it
Cruise - all lights come on, auto goes green but doesnt hold speed, he thinks he might have left it unhooked after doing the motor
Climate control - no air flow parked, moving at 55 good airflow, im guessing blower motor shot and just gettign forced air from moving, also blend door doesn't fuction or directional door
Power Steering - just needs a new pump, leaks fluid out as fast as you poor it in
Interior lighting - randomly pops fuse, scares me when I'm cruising, hit a bump and see a glow by my feet (fuse popping) all lights work when the fuse is good
Suspension - somehow stiffen it up
Right blinker, comes on and stays solid, all exterior bulbs are good (according to the fiber optic indicators) it just doesnt blink and the dash indicatior doesnt work, left blinkers work great everywhere
Exhaust - rusted out leaky, like to do a nice dual exit with tips tucked up under the body, barely visible, not sure if i love or hate this motor for the fact it sounds like a gasser 90% of the time, im used to the deep diesel rumble my Cummins makes haha
#37 ·
I am not a mechanic in any manner or form however I own a 5.7 GM diesel car. Larry is right that the diesels have the hydro boost system which is vastly different from the systems on gas powered versions. It may be a bit of a challenge finding a diesel parts car these days but anything is possible! :)
#42 ·
it stops decent enough, not on a dime by any means but it will bring it to a halt, by grabbing the wheel and pulling yourself into the pedal with all your mite.
Every store gave me the same run around, 2 weeks out, only 4 available in the country, and it must be teh same 4 every store was looking at, i just had napa order me one, im taking my truck on the trip so the caddy can sit while im gone they figure itll be here next tuesday at the latest.
car has some kind of a current draw, car sat 2 days in our heated shop and wouldnt start, batteries dead
#46 ·
I thought that, maybe switch is bad, pedal feels all the way released and no drag on the wheels
And my windshield chrome is good just needs to be reinstalled and all my dash bezeling is good just need the top dash cover, its like a vinyl.
Let me know a cost + shipping on some fillers might think on it zip here is 57053
#55 ·
Been driving it and getting more adventurous higher sppeds and seemed like its really wrapping out decided dam this thing needs an overdrive, then started paying more attention to it and it only shifts once near as I can tell, I figured its probably a 3 speed since I have Twp drive selections and a lo
#64 ·
New fan belts and had alternator tested, he said its charging awesome but batteries went dead on my way to work (headlights and fan motor) so had problems else where, discover for some reason passenger side battery wasn't flowing current or getting charged, lucky glow plugs still worked, flip flopped cables and shined em up, works good, charges good, whirls over better then ever now, new belts fixed my squeal and charging issue
Found I do have a bulb out and that's hopefully why blinker doesn't flash
#66 ·
Developed a shimmy yesterday about 20mph then a vibration, later on had a blow out, luckily was in town not going very fast, got a new tire mounted last night back in business, ever since the new belt and battery fix I've been amazed with how awesome this thing runs and starts.
Put a blinker bulb in and the blinker works good again, also replaced dash blinker indicator bulb, put the dash all back together, just drive it now for a while
#67 ·
Might want to replace the other 3 tires too?
