1 - 2 of 2 Posts
1995 Deville Concours
I wanted to program my key fob and when I youtubed it and the instructions were good, they said to remove the single black wire, which I tried by putting a paperclip into the outlet and it did not come out, What am I doing wrong?
None for now ;)
:welcome: Here are the correct programming instructions for your car follow the instructions EXACTLY how they mention:
1995 DeVille
Ignition in on position....engine not started.
Locate black wire coming from the trunk pull down assembly in trunk Ground this wire....locks will cycle lock and unlock within a few seconds to acknowledge programming mode
Press the unlock button on remote 1 twice within 20 seconds Locks will cycle lock and unlock within a few seconds to acknowledge programming
At this time press the unlock button on remote 2 twice within 20 seconds Locks will cycle again to acknowledge programming
If you do not have 2 remotes use remote 1 two times. Both procedures must be followed or you may cause your remote system to become inoperable.
This entire procedure needs to be started within 30 seconds of grounding wire or you will have to start all over.
1 - 2 of 2 Posts
