None
Car drove good yesterday with the abs and brake light on. Then the reduce engine power came up. I found a lose hose behind the SC area above the TB. Today I tried to duplicate the problem but instead I got two new codes. Now my car wont shift gears stuck on first.
Codes p0700(x2)
P0102
P0689
U0073
If calling some one could be easier let me know. Thanks
2006 STS-V and 2007 STS-V The Murdalac
Sounds like it might be a power problem. P0689 is a loss of power code and u0073 is a loss of communication code. P0700 is a general transmission code. Could be loss of power to the trans module. Check your fuse box.
Could also be a wiring issue.
None
Okay, ill check the fuse box tomorrow. I've message other forum members about this problem. It seems like i have a electrical issues. Hell..... Ill start with my fuses, then work to finding all the grounds on the car.
Is there a diagram that shows me all the grounds? I've notice my new battery keeps dying after a couple of hours after turning it off. The lights on my dash quickly flash on and off https://youtu.be/cFKY-r8SC7A Also, my engine doesn't turn off right away when pressing the button like my old man 05 Sts. is that normal?
2007 STS-V
No, that does not sound normal. Check the main red power cable coming from the battery to the under hood fuse box. It has a large bolt inside the box which connects it to the main 12v buss. This supplies power to all the fuses. It is known to come loose. A poor connection here can cause all kinds of problems.
