1 - 15 of 15 Posts
chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
So I finally got my impala ss steering box on. I line up the pitman arm with the threaded stud from the steering rack, go to put the castle nut on, get it halfway on and the threaded stud starts spinning. So I'm currently SOL. Anyone know what to do? Do I need to replace that threaded stud? If so, how would I do that?
What car? You'll have to put some pressure on the center link and/or hit it with an impact.
My Fleetwood brougham. I tried putting pressure on the center link then using a hand ratchet. I don't have an impact.
When you did you steering box, did you have this problem Sam?
84 Coupe w/500
Might wanna hit the center link, the pitman isn't really gonna move much since it's bolted to the steering shaft in the gear box. That idea should work though, try to hammer it into the seat. Maybe a c-clamp.
Discussion Starter · #14 ·
I can't remember which pitman arm I used but there was one that went around the steering dampener and one that didn't. If you change from your current one, the alignment will change.
http://s935.photobucket.com/user/csbuckn/media/_DSC0314-2.jpg.html
Might explain why I had to fight with putting the steering shaft on the spleen on the steering box (just a hair off, but enough I had to slightly reposition the box).
Since you replaced your center link, which would you recommend? I got the nut 3/4 past the top of the threads with an impact, but couldn't get it any further.
I figure I might as well replace it, since I don't feel like driving it like that (with the castle nut not fully/ properly seated). Anything else I should replace (bushings on it are newer- 2012)
Also, looking at them on rock auto, moog has one that is listed "for armored body". Does anyone know what that means? I.e. will it still fit my car?
1 - 15 of 15 Posts
