Hi all...This question has probably been asked many times already, but I need to ask. Will the 2.0 turbocharged engine run on regular fuel? What are the consequences of not using premium? Thanks in advance!
Great minds think alike I guess. I've been running 89 octane in mine since I've gotten it. Just couldn't bring myself to use regular.Even with my naturally aspirated 3.6 it will have a light "spark knock" under low RPM/higher torque conditions running 87 octane due to the way the 6L45 is commanded into higher gears at low speed for better fuel economy and I usually run 89 mid grade in mine.
Bingo.... In other words, if that difference is stressing you out then a car like a 2013+ Cadillac probably isn’t the one for you.
I agree that if the manual states 91 octane, buy it and run it. I run 93 exclusively to maximize performance.If premium gasoline ruins your budget, buy a non-premium car that doesn't recommend premium gas - even regular gas might go up some day, so buy something alot cheaper. These things are very straightforward. Pez.
I hope you contacted the appropriate local agency and filed a complaint against that station.I posted a story on HPTuners forum a few months ago about how i was on a fun afternoon spirited drive in the countryside and had to fill up with a brand i normally dont run. i immediately felt down on power so i plugged in my scanner and sure enough showed lots of knock. My car is far from stock, so not a baseline comparison, but i was so shocked at the difference, i went and bought one of those ethanol testers and tested 4 different gas stations to confirm my suspicions. The 93 fuel i bought was indeed much lower in octane than advertised.
