It's not the size wheels it's the tire diameter, what size tires do your have? I used the performance tune and then kept adjusting from there on the fuel and timing in the first two rpm bands.
The tires say 305/30 R26 109V but I have no idea how to change the perimeters ... i just want as much power as i can get...i just dont want to cause any damage to my truck...and i dont care about MPG...can you tell me what to change and what to change it to...i would really appreciate the help...thanks (oh yea and i have a cold air intake if it makes any difference) thanksIt's not the size wheels it's the tire diameter, what size tires do your have? I used the performance tune and then kept adjusting from there on the fuel and timing in the first two rpm bands.
Yea i have the perf. tune loaded and i use premium (90 octane) gas...Do you have the performance tune loaded? What octane gas do you use?
I am running 93 octane gas but I ping like crazy at WOT. I have the performance tune loaded. I also have a cat back and CAI. Any help you can give with the settings would be great.If you want to add timing you will need to run 93 octane, or else you will get pinging. If I get some time later this week I will post where my tuning is now.![]()
my mistake....i do use 93 octane...i double checked when i got gas todayI got no pinging on the performance setting, and have been moving the timing slightly, of course you only have slight adjustment anyway with the performance tune settings
ok thanks a lotNo I did not do it yet, but I have the truck with me, I will try to do it in the next day or two, it depends on the Father's Day shopping rush if I can get to it.![]()
