Do these cars come pre wired for options from the dealer or are there no wires run at all.For example if I have no heated seats but pick up a pair and switches are the wire there under the console or do I have to run them my self.
2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
Most car manufacturers are using one wiring harness for each model. So, if you do not have an option, the wiring will be there. This helps the dealers when a customer wants an option, that didn't come straight from the factory. The easiest way to find out, is check for the plugs. You may have to search a bit, but if they are there, they should be in the close proximity of where they need to go. The past three vehicles I have had all had wiring for options that did not come with the vehicle. Good luck
Don
