Hello to all the skilled people on this forum. I've been browsing through the forum and have come to the conclusion after having the same problems as others that there's a good chance I need a new power steering pump. Does anyone have the step by step procedure for changing this bad boy? I have already aquired another pump for $45 so I figure it's worth a shot.
97 Catera
it pretty easy.. locate power steering pump, remove serpentine belt, remove fluid hoses(be rdy for a mess..try your best to catch old fluid in some suitable container), remove faulty P/S Pump, replace with new power steering pump, reattach fluid hoses, replace serpentine belt, refill with new P/S Fluid, start auto, fill P/S Reservior as necessary...FYI P/S pump is located on drivers side of engine above A/C Compressor. post with any further questions...
Thanks very much Steven, I will be doing this job next week. I will let you know if i need any further info.
DBC
