1 - 8 of 8 Posts
NONE
I just bought a 2006 STS-V with 57,595 miles on it from an individual that has a GMPP with it. I have to send $50 to GM to get it transferred before I can take it in for warranty work. I started noticing a small puddle on my driveway every morning around the inside of the front drivers side wheel. Tonight I checked my fluids and found that I was low on power steering. I bought a big bottle of PS fluid and filled it up and I will continue to do this until I get the warranty in my name. Has anyone had a PS leak around this spot before and if so where was it leaking from? Is the GMPP going to cover this type of problem and how do I get it fixed where they will pay for it? I am pretty good mechanically but still have a long way to go, but also am new to warranty protection so I am hoping to find some friendly help here.
2013 OBM CTS-V Coupe
If you have the GMPP is should be covered depending on what coverage you have. Check your policy as it should state what the coverage is. You can check to see if the reservoir is cracked or leaking, also check the hoses going in and out of it.
NONE
Discussion Starter · #4 ·
So today after leaving it on alone all day when I started it after work the low engine coolant light came on but went off before I could get it in gear and roll out of my parking spot. After getting home I let it cool down and then checked the coolant pressure tank and it was half full. Isn't it suppose to be completely full? I told you I am a novice and need some help. I still can not find where the leak or leaks are coming from, but I haven't tried looking for it while the motor is running. I am just going to keep checking fluids until I get my paper work done for the GMPP.
STS-V 1 OF 3 BLK ICE & TANGO RED
I am not sure how long it takes to tranfer the warranty, but GMPP is a nononsense warranty - I would get that paperwork done ASAP, no need to play mechanic when you have a warranty.
2006 STS-V
I took the front wheels off to get new rubber and noticed that the of the left frame was all "misty" looking -- immediately thought of this post and wondered if you had your power steering leak fixed. No drips on the floor yet, but it is becoming a dirt magnet.
NONE
Discussion Starter · #7 ·
No I haven't received my transfer paper work for the GMPP (warranty). I don't think it is steering fluid anymore, cause I got a low coolant message on the dash board. I topped off with water and haven't lost any fluids in about a week. I don't think the problem fixed itself, so I am going to take it to the dealer as soon as I can do it with the warranty in my name. I have had my STS-V now for about 2 months and love everything about it accept the windows are not tinted.
1 - 8 of 8 Posts
