1 - 8 of 8 Posts
2001 Seville STS
hi there,
i have another problem on my seville..
i know the steering pressure hose is leaking (waiting for part ordered today) .
Today i start my n* after 7 months. no more than 2 minutes (to see coolant flow on the return hose to tank)
after stopping engine, i check some things and the steering tank....
when i open steering cap, i heard a pcchhiittt... like it was already pressure in it ! (never heard that before..)
and i can see tank is full of steering fluid bubbles !
after waiting about 15 minutes, there is no more bubbles and level is still at mid stick..
i think the fluid is burnt (with the orange color ?) no ?
when i receive my pressure hose, i plan to flush all the fluid, but how to do that properly ? have already seen the FSM but it's not clear...
edit : when i want to do a test drive i can heard lot of noise when turning steering wheel.... and at some point it is hard to turn... hum... i think i wait for pressure hose delivery and flush the fluid before any other things...
hi there,
looks like the system is sucking air -
and foaming up the PS fluid -
2001 Seville STS
yes, i will wait for the new hose.
so, when i made the replacement, do i need absolutly to bleed the steering system ? (don't have a vaccum tool like FSM say to do...)
your existing fluid is contaminated with "micro-bubbles" that will never "pop" -
so - you need to drain ALL the old fluid from the system -
to bleed the system -
the easiest way is to raise the front tires off the ground -
with the engine OFF -
SLOWLY turn the steering wheel lock-to-lock several times -
then - use four pieces of cardboard - about 1 foot square -
place two of them - stacked - under each front tire -
this allows the wheels to be turned easily -
cardboard on cardboard -
rather than scrubbing the tires directly on the pavement -
start the engine -
turn the steering wheel SLOWLY - lock to lock - several times -
this will purge any air from the system -
1999 Deville Base; 2001 Seville SLS
slowly turn the steering wheel lock-to-lock several times -
start the engine -
Or, instead of cardboard, fold up a couple of large lawn/leaf bags into foot-or-so squares. They make some SLICK sliding pivots. We used to do toe checks on RV front ends like this.
Several times?
It can take 100 times to get all that air(bubbles) outta there!
Sent from AutoGuide.com Free App
actually - referring to the OP's fluid -
he will NEVER get the micro bubbles out -
which is why I said to drain ALL the fluid from the system -
1 - 8 of 8 Posts
