1 - 20 of 33 Posts
· Banned
1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
If you had a finite amount of money... lets say $2500, what kind of engine would you build up and why / how? The goal is the most power you can get out of it without making it a race dedicated engine.
i think i would go with a sbc 350. Theres such a huge market that parts are pretty cheap, theres more avalable and with so many resorces on them it would be easy.
AKPsiMC03 said:
one of my friends just built a 433 HP, 460 ft lb, 350 for that price and put it in his firebird.
The 350 is your best bet. Your going to have to do a lot of research on what parts to put on it to get you the most bang for your buck. I recommend going to a library and reading hot rod mag, Super chevy etc.... they have budget motors in there mags all of the time. Also look into a rebuilt motor and rebuilt parts. Heads, cam, carb, exhaust, etc....
· Banned
Discussion Starter · #6 ·
I was thinking that too. Then I thought I'd look for things I could do with a Cad500 when I get one, and I figure
$250 for a usable 500 from a junkyard
$250 for an Edelbrock performer intake
$500 for 10:1 pistons
$450 for cam, lifters, valvesprings
$200 for a good set of headers
$200 for a carb, or maybe keep the good old stock Qjet and clean and tune it.
With those mods, I'd expect the Cad to hit around 410-450hp with 500+ torque. The cost would total $1850, so even if it didn't hit my estimated power, there's enough money left over to put a good nitrous system on there for an extra 150-250hp.
I don't know if that setup would be better than a 350 though since I haven't looked into 350s much.
Q-Jet wouldn't work with your edelbrock performer intake. I suggest getting an edelbrock or demon 850cfm carb for that setup.
1995 FTS
I don't get the question. Your asking to modify an engine but not to make it race dedicated :confused: obiously once you start modifying an engine it will be producing more hp/tq which would mean better performance which would be better for racing.
· Banned
Discussion Starter · #9 ·
Alright if you want to be a pain about it, I mean an engine that is still useful as a daily/weekend driver. So it doesn't need race gas, doesn't need work after every run, etc. Of course there's no chance of making a pure race engine for $2500 anyway. Also, it's obvious that any performance increase would be better for racing but it's also obvious that performance modifications don't always result in a pure race engine..
'05 Expedition
I have to admit I was salivating last night when I was doing 1/8 mile test runs in the Fleetwood I borrowed.
I agree with MM9. The LT1 has a lot of potential with just simple bolt-ons. And it was pretty common, too.
The Fleetwood was scary when I started thinking of all the extra power I could get out of it with just a few hours here and there and a only few hundred dollars spent. I used to spend my Sunday afternoons watching shows like "Crank & Chrome" and being shocked and awed by their dyno runs.
But I think I'm over that after my Honda Prelude/riceboy experiments. They were fun, and they did yield some respectable results, but I don't want to do that kind of stuff to my daily driver anymore.
What deterred me and brought me back down to earth was how I would probably end up spending twice as much on brakes and suspension to counteract the increases in HP. That's not the kind of work I know how to do, or ever want to learn.
· Banned
Discussion Starter · #12 ·
Hmm, that sucks. At Jegs, it says the stock ac compressor won't fit - they should probably warn people that the carb won't work either. Can you tell me why it wouldn't work?
well you might be able to use it if your intake manifold was either built for a q-jet or was all open, instead of the four ccut out circles. The Q-Jet doesn't have equal size for the manifold, the Secondarys are a lot bigger than the primarys, so they wouldn't fit into the manifold. I don't know if that just confused you. I don't really have any better way to explain.
Here is a picture of the Q-Jet Gasket to let you know what i'm talking about
http://www.nardek.com.au/nard040.jpg
Here is a picture of an intake manifold
http://www.boss302.com/intake4.jpg
see what i'm talking about? They're all equal size and secondarys wouldn't fit.
I guess you could just go for a box open intake manifold, but you why do you want to go with a Q-jet so bad? Just get a regular edelbrock or demon carb 850cfm would be nice. q-jets just have a bunch of extra shit on them.
· Banned
Discussion Starter · #14 ·
The intake manifold pic you have doesn't look like the Edelbrock one:
http://static.summitracing.com/global/images/prod/large/edl-2115.jpg
http://www.jegs.com/photos/3502115.jpg
It says the manifold will work with square or spread bore carbs, which doesn't help me cause I don't know what that actually means. With the Jegs pic and the gasket pic, it looks like it could work though.
I'd like to be able to use a QJet because I have one... which is cheaper than buying one. QJets are perfectly good carbs.
· Banned
I don't mean to get off topic here.....I just wanted to give a little info on carbs and intakes.
There are adapters that will let you mix and match carbs and intakes.
Here's a link that shows some of the adapters Edelbrock has.
http://www.edelbrock.com/automotive/install1.html
I think I'm going to use the Q-Jet (rebuilt and modified, if needed) on my 500 with the Edelbrock Performer intake.
· Banned
Discussion Starter · #16 · (Edited)
Wow, I was looking at that about 5 minutes before I saw your post. And yeah this went off topic a while ago.
Can anyone tell me if the edelbrock manifold will fit a QJet without an adapter? If I put it in my 78, the air cleaner assembly I have won't fit under my hood.
1 - 20 of 33 Posts
