97 eldo,2011 cts-v
does gm still make power antenna for a 97 eldorado? if so is it exact fit? dealer said that may need some modification.
You may need to reuse the rubber (weatherstripping) around your existing antenna.
98 Deville, '15 Ford Fusion Hybrid Titanium, '12 Ford Escape
I gone mine off ebay for my Deville, and I did need to reuse the rubber "grommet" that was on the old one that 'secures' the antenna when it goes through the hole in the body.
I think i also saw a post here on this site on how to rebuild the power antenna yourself, only after i bought a replacement.
1996 Eldorado
All mid to late '80 up into the mid '00 power antennas equipping GM vehicles are the same apart from the rubber grommet (witch is specific to the car's body shape). You may find that a Chevy power antenna is less than a Cadillac power antenna. It is essentially the same part just aimed to different buyers.
The bracket that attaches it to the frame would also be different. My replacement unit bracket did not match but it just unbolts.
That is great info. I wish I had saved the other one and rebuild it as a spare.
