Thanks to everyone who gave me advise on the HEI conversion I was considering a while back. I finally did it and was amazed at how easy it really is to change out a distributor. I even was able to figure out the timing and get it all aligned so that it runs smooth with limited knowledge I had from this site and from watching other dudes adjust my timing before. And the thoing runs beuatifully...when I warm it up all the way and advance the timing; In the process of changing out the distributor I further stripped an already stripped stud and bolt. My question is, does the stud the distributor clamp bolts on to, pull out of the block...or am I up s%#! creek.
I'm pretty sure it pulls out...so I was basically wondering what is the best way to pull it out. Right now I have it bolted down just enough so that it doesn't come flying apart....I constantly have to pull over and adjust the thing. I'm glad I don't have a hot wire to the coil anymore. That would suck.
