3761 - 3780 of 3816 Posts
'99 Seville STS; '96/7 ETC
All I got was the all too familiar exhortation to update my account to allow 3rd party hosting - I don't even have an a/c!
1985 Cadillac Fleetwood Brougham d'elegance - 1969 Coupe DV (R.I.P.)
Not a picture of my cadillac but I scored a set of these for a really good deal. OEM wires!! Waiting till I get the bumper filler situation squared away and to have a decent place to park the ol' girl (right now the '58 GMC and the '18 STI are in the garage) before I put them on her.
1989 Cadllac Brougham
These lights contains electroluminicent tape (el tape) which basicly is a phosphor covered tape which glows steadily when supplied with AC power . The down side of this is that they slowly degrade and eventually break from the suns UV rays. ( we are talking 10-15 years, which is why most of these on older vehicles are broken since long)
Before you do anything, check that your inverter is working.
These lights run on 110V AC which is supplied from an inverter located on a left hand side beam behind the carpeting in your trunk.
I ordered some EL tape for 2$ on ebay and it came with an inverter as well. If your inverter is shot you can modify the new inverter which came with the tape using the contacts from the old inverter and plug in right in.
In my case both the inverter and the EL tapes were dead.
If so, do the following:
When you have the light assembly out of the car, take a fine and sharp knife and gently, very gently pry the plastic lens away from the housing and remove the light strip inside.
Take your new EL tape and cut it to fit inside the housing.
Use a soldering iron to gently solder the old connectors onto the end of the light strip. There is a copper strip running through the length of EL tape, make sure to solder one connctor on to the right side of this copper strip and the other to the left side of the copper strip.
When the above steps are done, use the small inverter that came with the EL tape and a 9V battery to test operation of the lights before assembly on the vehicle.
Before sealing off the light assembly take some clear tape and seal of any cut edges on your new EL strips, You can allso put clear tape lengthwise over the EL strip to protect it somewhat more from UV rays.
Then use a clear super glue to glue the lenses back onto the housing and wait for it to harden.
Next, use some clear silicon to seal off the assembly from moisture, this is a crucial step if you want your lights to last.
Assemble your new lights back onto your vehicle!
If you decide to to this feel free to contact me for more help!
New NOAH California car cover and a fresh wax. Bumper tillers are on the way
1989 Fleetwood Brougham
Rebuilt the air conditioner and am now pumping it down. It's held vacuum with the pump off for several hours so charging the AC should be on the list for tomorrow...
84 Coupe w/500
Did a new 3" exhaust all the way back(way too loud now), custom 4/2/1 tuned long tube headers, cleaned up the wiring and got some more seat time. Tranny wasnt acting quite how I wanted it to at the track but was able to blow the Camaro away without flooring the throttle(still hate to rev it passed 6k where max HP is). So far the motor has been good to me, tranny is getting weak though(winter project).
