popping/clunk noise sometimes when reversing
26K views 206 replies 11 participants last post by  sts 03
Just recently sometimes when I'm reversing I get a popping/clunk noise from the front.it does it as soon as I hit the gas.seems like it does it mostly when the wheels are turned when I'm backing into my parking.it doesn't do it all of the time but tonight it seemed to be alot louder.
#77 ·
I talked to you already about the mounts in the PM and by the sound of the squeaks over speed bumps I bet its them, also I haven't paid too much attention to it but that also proves the fact that I don't hear the popping noise anymore when reversing. I'd have them checked out and like I said, make sure your struts are in good condition before replacing the mounts since they can do the job at once and save you the labor.
#78 ·
naif said:
Squeak only when both wheels move the same direction at the same time (not when going over a speed bump at an angle)? Look at the sway bar bushings.
So if it squeaks going straight over a bump then check sway arm bushings if going over a bump at an angle check strut mounts? It even squeaks when hitting dips in the road but mostly going straight over a speed bump.
#96 ·
Oh ok thanks for letting me know that.one more thing about the alignment would bad mounts affect the the steering wheel being off center, cause I've had a few alignment s this year and every time the steering wheel is off center, inner and outer tie rods new and both control arms.
#98 ·
Any particular strut mount to stay away from? What are some good ones delco,moog,Monroe? Oh yeah I was trying to take that shaft bolt off but I couldn't get it to loosen (need help) but when I turn the wheels back in forth the center strut shaft moves around anyways, so its probably a waste of time to get that nut off to check the mount if the shaft if moving anyway.
#101 ·
Yes, you'll need a spring compressor. You'll need to remove the strut, hold the spring with the compressor, swap the mount, and reassemble.
Take a look at your spring isolators before you order the mount. If they're torn, or don't look too healthy, order new ones. They're pretty cheap, and replacing them will take an extra 30 seconds.
Have you inspected the other mount as well?
