I have a 2009 CTS with AWD and 139k miles. I started having a loud popping sound and jerking feeling which feels like it's coming from the front when backing or turning the wheel at slow speed, mostly after driving for a few minutes. Took it to a GM dealer who said the rear differential needed a fluid change. They changed the fluid and said to drive it a little and it should work itself out. They also said there was no shavings or debris in the drained fluid.
Drove it a couple of days and called GM dealer to tell them problem wasn't solved. They had me bring it back and after 2 days, told me they couldn't diagnosis the issue because they needed "special tools" that only a Cadillac dealer would have. Took it to the Cadillac dealer who after keeping the car over night said the "transfer case" needs replaced because it "locked up."
Remember...it only does it when turning the wheel (left or right) and when backing. Drives down the road fine. No other symptoms. No warning lights on. No leaks. New tires put on a couple of months ago. I had a 2005 SRX that locked up the transfer case, and when it did, the car stopped dead in it's tracks and made a horrible sound it you tried to move the vehicle at all.
I'm just not sure it's a transfer case issue and I don't want to keep paying for diagnoses and "repairs" to have the same problem. Anyone else have this issue?
