1 - 20 of 20 Posts
1995 Deville 4.9
Hello CF, I have a 4.9l 95 deville and I'm getting terrible gas mileage, the engine has 60k. I've changed plugs,wires,O2 sensors, 8 injectors, computer, engine coolant sensor, the whole distributor,FPR, idle air control valve, map sensor, throttle body, EGR valve and control solenoid motor, resonator, PCV, fuel filter and the milage sucks. Did I miss anything or any suggestions
Please define "poor gas mileage" - in town, suburban, open highway, long runs.
OUCH..... I recently got a 2003 deville and mine runs between 19.3 and 25.4............ I'm happy. I doubt if the automobiles are comparable...
Might have been easier to list the things you HAVEN'T changed.
17 highway is WAY low.
Have you checked for a vacuum leak? Maybe a dragging brake caliper? Partially clogged CAT (how's the performance?).
Have you pulled the DTC's?
2004 Deville
2004 Deville, Silver, Gone, but not forgotten, 1972 Eldorado, 1974 eldorado, 1975 CDV
Also make sure your tire pressure is where it should be, and that it doesn't need an alignment.
1999 Deville base
95 Eldorado, 99 Deville, 05 CTS
I agree with Ranger, a partially clogged cat. I have a 99 Deville, everything is good on mine, xcept the cat, which I know is partially clogged, because I took it off and tried to clean it. Wouldn't hardly run at all before I unclogged most of it. Runs great now, but like Ranger said, performance is down, which drops mpg.
When mine was running poor mpg, it was in constant open loop due to low water temp. Check diagnostics while running to see what state it is in.
1995 Deville 4.9
Discussion Starter #11
Hello I had the cat checked, and he said was good, no rattling but the resonator had a hole in it so I replaced that. Should I change the cat anyway? It's the original
Did you use an after market cat? I was told aftermarkets triggers a check engine light. Found an new cat on eBay, he wants $400+shipping. Is that about right
SC
1999 Deville base
How did he check the cat? The only way I know of is by putting a gauge in one of the front O2 sensor ports and check for back pressure at idle and at 2000 rpm. I took mine off, and I could actually see that the honeycomb was clogged up.
1995 Deville 4.9
Discussion Starter #13
Didn't watch how he did it,,it was a muffler shop out in the country. Any recommendations as to where I should take it to be tested?
1999 Deville base
Also, how does it run when you put it to it? If it runs like a bat out of egypt, and revs right on out till it scares you, then the cats probably ok. Make sure you have no vacuum leaks anywhere at all. Look and listen real good. I use a piece of vacuum tubing in one one ear, like a stethoscope, and stick it all down around the intake manifold and everywhere I can find that looks suspicious.
1999 Deville base
If you did all that work yourself, you are adept enough to find a gauge and check the cat yourself.
I would think any muffler shop can test a cat and would try to sell you one if they could. If your muffler shop said it's good I would be inclined to agree with them. I would be verifying vacuum very early in the diagnosis anyway.
1995 Deville 4.9
Discussion Starter #18
Thanks I'll take it to Midas for another test, I know they'll put on an after market which I was told would trigger a check engine, might have to spend $400 for a new GM converter I saw on ebay
1 - 20 of 20 Posts
