1 - 12 of 12 Posts
Normally, my average fuel economy is between 20-21 mpg. Lately, I've been averaging about 16.7 mpg. It is cold in my region of the country and I have a remote starter, but I shouldn't have that large of a drop. I don't have any codes, but I noticed that my injectors sound noisier than usual. I cleaned the throtle plates about a month ago and I changed the plugs 8 mos. ago. I don't smell gas while driving. Any solutions? Thanks
Greg
94 Eldorado, and a 99 ETC
First try refueling at a different gas station. Maybe the one you're going to hasn't switched to the winter mix yet.
What year is your car?
My car, the 94 eldo, had very poor fuel milage (14mpg) when the fuel filler pipe got a hole rotted into it.
· Cadillac Owners Connoisseur
If you idle the engine to warm it up, the mileage figure drops while it's sitting there. It makes sense if you think about it: The miles traveled remains at zero but the fuel consumed is increasing. The mileage has to drop because you are getting zero miles per gallon. My hypothesis is that the mileage would go back to normal if you weren't idling the engine to warm it up. That's the down side of remote starters. Wasted fuel.
1993 STS, 1997 STS, 2002 SLS, 2007 CTS 3.6
It will amaze you how much the MPG drop when left ideling. I was amazed after 30 min stuck in traffic I dropped almost 5 gallons PM...
I would try to reduce the warm up time and see if that works..
Idling will reduce the MPG reading, and the rate at which it declines depends on how much data the system uses during the calculations. If you recently reset the average MPG and/or fuel used data, the number will drop more quickly, but will also rise again quickly when you start driving. If you haven't reset those values for thousands of miles, it will take longer, but it will still go down. Realtor1, I imagine yours were reset sometime in the recent past if they dropped 5 MPG in that short a time.
Greg
Even with winter mix fuel, anticipate about a 10% decrease in fuel economy as fuel atomization does not occur as efficiently at colder temps.
Colder weather = lower air pressure in tires. Check to see that tires remain properly inflated with colder temps.
Ditch the remote start/idle exercise - you're wasting fuel and the Northstar does not require any warm-up time.
This should get you back near your warmer weather mpg's
sjwoodruff, I'm with you on the tire pressure and idling, but I don't understand the winter blend fuel and atomization points. I thought the primary reason mileage dropped in cold temperatures was that the denser air requires more fuel to create an efficient burn. Since more oxygen fits into the same cylinder charge, you have to let more fuel through the injectors or it will burn too lean. I've never heard atomization brought into the discussion before. That seems like a function of surface tension, but I don't see how that would be affected by cold temperatures. I'm not doubting you, because I'm certainly not an expert. I just don't understand the mechanism you're describing. Along the same lines, what is the winter fuel blend in your area? Here in the Chicago area, winter blend fuel may contain less alcohol than the summer blend.
2010 Black Cherry CTS AWD
The N* engines really only need about 15 seconds after starting. When you start to go with it, just don't think about doing any WOT's right away. Just drive her nice and easy until it's properly warmed up. By the way, I have remote start too on mine and it beats up the milage. Just start it when you're on your way out the door so it has has the small warm up time before you get in and go.
Good question. I'll try an add info w/o making the explanation too long and drawn out...
Point 1) Cooler, denser air will require more fuel to avoid burning lean. However, more air + more fuel = more power. Think of turbocharging or supercharging. An engine will create more power at cooler ambient temps - that's why many real world performance tests are done at dawn when the air tends to be heavier. This will decrease fuel economy slighty, but only if you're driving the car harder than you normally would, follow? Similar driving habits should yield nearly imperceptable decreases in fuel economy if all else is equal. But we know this isn't the case due to our winter fuel mix, bringing us to...
Point 2) <Courtesy of Chevron> Composition Changes: Gasoline is composed of hundreds of hydrocarbons, each with its own energy content. The energy content of the gasoline as a whole is the weighted sum of the energy contents of the component hydrocarbons. The relationship between gasoline fuel economy and energy content is advantageous because it can be used to predict how composition changes will affect fuel economy. Replacing some hydrocarbons with others may change the energy content of a gasoline. A more significant change in energy content occurs when a gasoline is oxygenated – when some hydrocarbons are replaced by oxygenate(s). Oxygenates are combustible liquids that contain oxygen. At present, the most common oxygenates are ethanol and methyl tertiary-butyl ether (MTBE). Ethyl tertiary-butyl ether (ETBE) and tertiary-amyl methyl ether (TAME) are used to lesser extents. Because oxygenates can be viewed as being "partially burned" hydrocarbons, they have lower energy contents than hydrocarbons, and, consequently, oxygenated gasolines have lower energy contents and lower fuel economies than conventional gasolines.
Point 3) Atomization: To assure that fuels have the proper volatility characteristics, refineries adjust gasoline seasonally. Due to additives, during the cold, winter months, fuel will be more volatile. This helps good “cold” start and warm-up performance. Conversely, during the hot summer months, the fuel mix tends to be less volatile. This will help minimize the incidence of vapor lock and hot driveability problems.
On it's own, fuel is very volatile (it likes to evaporate). The warmer the temperature, the more it will evaporate (atomize). IC engines don't operate well under a wide range of variables. The fuel blends tend to seasonally adjust the volatility of the fuel in order for more efficient engine operation. Though this is the case, the pro-volatility agents used in the winter result in a lower energy burn in the combustion chamber. Less power from combustion = more fuel used to create power = lower mpg.
Point 4) Other items to consider: Engines take longer to warm up. During this time, they are running heavy at high RPMs. Even after you get going, all the car's systems have to work harder to maintain a normal operating temperature. The air is denser when it’s cold and it’s likely to be windy in the winter resulting in more wind friction. The roads can be covered in snow and ice. Tires are stiffer. Until they warm up on the highway, they roll less easily. And the tire pressure is likely to fall below the desired range. This all adds up to more resistance. In the winter, you use your headlights, defrosters, and heaters more resulting in more strain on the alternator and parasitic losses to the engine.
Two-thirds of the friction losses in an engine are estimated to occur during hydrodynamic lubrication and one-third during boundary lubrication or mixed hydrodynamic/boundary lubrication. The newer energy-conserving motor oils are designed to reduce friction losses from both types of lubrication by tailoring the viscosity characteristics of the base oil and the chemistries of the friction-modifying additives. Colder oil doesn't lubricate as well though, so there will be more friction losses there. The same holds true for transmission fluid.
OK, longer than I hoped for, and I now officially feel like a complete nerd :)
1 - 12 of 12 Posts
