1 - 10 of 10 Posts
2005 STS4
Mine was just replaced a couple months ago and the part number on my receipt is #88986858. Must be a new superceded number because the manual shows the OEM number to be #7223-6055-30. Probably better verify with the dealer parts dept though. What kind of problem are you having?
'05 CTS 3.6L
Is this the same relay that turns off the headlights when daylight breaks?
My headlights stay on all the time and very rarely turn off and go to the driving lights
No, that is just the Twilight Sentinel turning on the Low Beams. This relay is ONLY in cars equipped with IntelliBeam. If you pull the cover off your underhood fusebox, there is either a relay or a spot to slide one in just to the front and right of the fuse center.
1 - 10 of 10 Posts
