1 - 9 of 9 Posts
92 Eldorado Touring Coupe
I'm helping my neighbor out with his '75 Eldo convertible. For me, it's a priviledge and honor to be able to work on the car.
The radiator needed to be replaced. Everything was going along smoothly :cloud9: until it was time to reattach the tranny coolant lines. I can't get them to seal. Doesn't matter how much I crank them down. And there is less thread showing than when they were attached to the old radiator. :banghead:
Is teflon plumbers tape acceptable here? Will it hold up to the tranny pump pressure? Or is there something else I should be doing? I'm open to suggestions.
Thanks in advance. :bows:
'98 STS (RIP @ 206,xxx miles)
Sounds like the replacement radiator does not have the correct tranny plumbing fittings. Do you have the original radiator to make a comparison??
I would not trust tape as a permanent fix at those pressures/temperatures.
Still have the original. I did a check before I put the new one in. Learned the hard way a while ago. But I didn't clean up the flare or threads before I reattached. Cross threading isn't evident as I could start the fittings by hand and turn them in about 4 threads before I had to start using the wrench.
· Premium Member
Teflon tape extrudes into the inside of the fitting and contaminates whatever is in the system. It is absolutely prohibited in aircraft fuel systems. When found in filters it looks like hair. It can easily get caught in ball check and servo valves. Definitely bad news.
Also I learned from working with propane and natural gas,that it will break down.
· Administrator
Sort of along the same lines for oil systems.......I replaced the oil pump and filter in my heat pump emergency heat backup oil furnace this spring. The instructions for piping up the oil pump specifically state "........do not use Teflon plumber's tape on any oil line fittings, supply or return. Pump warranty is void if Teflon tape is used."
1 - 9 of 9 Posts
