2000 Deville
OK -
New to this forum, so I apologize if something like this has been posted elsewhere, but I looked and couldn't find anything.
My number 6 cylinder is fouling plugs, its a slow process, takes about 6 months to completely fail. See photo. I have now had to replace this two times and would like to know why or what the root of the problem is.
I have had suggestions ranging from piston to fuel injector to you wouldn't believe me if I told you.
Anyway, any help on diagnosing the problem is greatly appreciated. This forum has helped me so much, everyone who participates here is the best. Keep up the good work!
Looks like ash fouled plug caused by oil getting into the cylinder, bad fuel or fuel additives. Since it's happening with only 1 cylinder, I'd look more into oil leaking, possiblythrough the valve area.
could be several things -
what brand and # spark plugs?
bad coil -
bad fuel injector -
oil leaking into #6 -
low compression -
because it is easy to do -
do a compression test on the front 4 cylinders -
with the engine running listen to the fuel injectors -
should be a distinctive CLICKING -
measure the resistance of the front 4 injectors -
note any difference -
WOW! :shocked2: That looks like a growth on it.
Lot of carbon on it. I'd look at the injector first.
