2004 CTS 3.6 and 2001 Seville SLS 4.6
2001 SLS. Removed plenum to replace boot. My question is, there is a valve with a small hole in the center on the plenum below where the boot slips on, that is held in place by 2 torx screws. What is this valve? And should you be able to blow thru the little hole?
It's an overpressurization valve (or backfire valve). It's there to keep the plenum (manifold) from cracking in the event of a backfire.
The valve itself should not be able to be blown through, but the hole in the plastic is not a sealed part of the valve.
Thank You
If it were bad would it cause it to not idle?
2010 DTS
Yes, if it where stuck open it would be a big vacuum leak. That said, I've never heard of that before. If you had an idle problem and a P0171 & P0174 code, it was caused by the ripped plenum.
P.S.
Be sure to give the TB a good cleaning while you are in there.
