I tried searching before posting sorry if this is a repost. I have a 05 CTS-V LS6 of course mods:
Patriot performance stage II.5 heads
cam- 232/234 .595/.596 lift
headers
corsa exhaust
cold air intake
port and polished TB (which TB might be the cause)
50 wet shot
those are the main mods.
I had a friend HP tune my car. but before we tuned it we took it on a test run after the mods and under full throttle went into power reduced mode. everytime. after the tune it was fine. well its doing it again. we did have an issue on not being able to do a speed density tune where we tune out the MAF. the car would not allow it. when we would try it would go into power reduced mode right away. so we tuned it the best we could w the MAF still in play. now it runs fine under full throttle unless i run it from a dig and shift hard into 2nd. as soon as it hits 2nd it goes into that mode again. but 2nd to third full throttle pulls and so forth its fine. i can however go from a dig and if i shift slow and ease into full throttle into 2nd its fine. I think since we had to tune w the MAF still on the computer is retuning itself. keep in mind right after the tune i could run the car to hell and back and it would run strong. nitrous was tuned w a wideband and thats irrelevent to this problems. i have only used it when we tuned for the right pins... thank you guys for your help!
headers
corsa exhaust
cold air intake
50 wet shot
