1 - 2 of 2 Posts
2001 DeVille 2002 Escalade
I am in the middle of changing the sensors and I am stuck. On the oil filter unit I removed the front two lines (1" wrench) but I can not figure out how to remove the third line. Does it screw off? I dont have a wrench that big? I am so close but stuck it looks like it has wires going in it. What should I do?
There should only be 2 oil lines on it. If the 3rd one has wires to it, I suspect what you are looking at is the oil pressure switch. Unplug the connector and remove the adapter with the switch in place.
1 - 2 of 2 Posts
