1 - 20 of 54 Posts
Re: plasti dip grille...
It definitely looks good.
2008 Cadillac CTS 3.6DI
Did 6 coats cause it was my first time messing with this stuff...but I think I was good at 3 or 4 lol...
2008 CTS(Pluto)
Not bad....how do you wash your car? Automatic or hand wash? I watched a couple videos with plasti dipped parts and it seems to hold up well. Just wanted to see how your grille is holding up.
Discussion Starter #8
pluto...ive been through the auto car wash 5 or 6 times since doing the grille...no probs...its actually pretty durable so give it a try...they wipe down the car after the wash and theres no sign of breakdown in the pasti-dip...pretty amazing material...
2011 cts premium
I've been through the car wash with my plasti dipped grill and rims twice a week for the last year ! probably 50+ times everything looks the way it did the first day I dipped it ! Just Go for it you'll be glad you did ! After you do plasti dip your grill you'll be looking for things too dip :)
Did you remove the grille for the dip ? If not how did you avoid overspray on the inside behind the grille ? I've never used this stuff before and i'm really considerin dipping my grill.
2011 cts premium
To plasti dip your grill , first you want to mask off the sides of your grill with about a half inch boarder around your grill . Next step would be to make sure you have a warm can of plasti dip ( goes on better ) I used a piece of cardboard behind my grill to Protect my radiator from over spray . Start off with light coats over entire surface of grill and allow to dry . You should put on at least 4 coats of dip on your grill ! than unmask the tape than take out cardboard !
Should take no longer than 45 min . Use your judgement on your emblem if you want to remove the dip from it !
Discussion Starter #15
what crippler said...
as far as the emblem...i sprayed directly on the emblem and peeled the plasti dip from the emblem when finished...it presents a clean professional appearance and is easier then masking it off and worrying about peeling the dip from the rest of the grille...
2008 Cadillac Black Raven CTS4 3.6 DI, 1992 GTA Trans Am
Thank you for motivating me.... When warmer temps return to Ontario in the spring I will be doing this. :)
CTS Coupe
Looks great. Did you spray over the chrome bezel at the top and sides and then peel it off the chrome?
1 - 20 of 54 Posts
