2014 CTS Vsport
Has anyone seen circumferential tread groove cracking on the P Zero run-flats? My '14 Vsport (bought a month ago at 7400 miles) was a "service loaner" and I strongly suspect the car was driven in below freezing temps this past winter. I realize this is not the same type of cracking that's pictured in the service bulletin (#13-03-10-001A), but can't help but think it might be related. Just looking for input before I contact the dealer... I obviously want to take care of this before 12000 miles rolls up and the 100% tire replacement pro-rate changes to a lower percentage.
For some reason, I couldn't attach photos when I posted this... they are now up, in post #2. The cracks are in the bottom corners of the 3 circumferential tread grooves and range from less than an inch to several inches long.
Before you spend lot of effort, you may want to go ahead and check with dealer if they/Cadillac would replace the tires.
P Zeros on VSport are summer tires, and does not come with any mileage/uniformity warranty at all.
2014 CTS Vsport
Where are you seeing this "summer tire" exclusion? I find no such disclaimer in my warranty booklet... only the statement that normal tire wear or wear-out is not covered.
2014 CTS Vsport
It occurs to me that you're talking about the Pirelli warranty, which does state that P Zero summer tires are not warranted for mileage. But I'm referring to the GM tire warranty that is part of the 50000 mile/4 year bumper-to-bumper coverage.
