1 - 11 of 11 Posts
Attached are pictures of the new diff (including P/N) and the failure I experienced.....axle broke, taking out the bearing race of the diff.....it was whining and grinding anyway....so time for the new one.....still quiet.
Discussion Starter · #4 ·
Sorry guys......my fault.....no the failed diff in the pictures is the OLD ORIGINAL diff...New one still quiet.....Marty.....the splines weren't twisted.....the axle itself twisted....kinda' like winding up a rubber band if you know what I mean...you could see the twisting of the metal. I have your email address and will send you better pics now.
2009 Z06 / 2013 F150 EcoBeast / 2008 Twin-Turbo Bimmer
Interesting ink stamp on the new assembly - "NOISE TEST-OK". Wish the original one in my V had that... :)
From a service engineering perspective, it appears the more cost effective solution for GM would have been to replace the chewed up bearing race and install a new half-shaft. Technically, your "diff" was ok as exceeding the load capacity of the half-shaft was the likely failure mode. :hmm:
What you now have is definetly the new and improved O6 unit. You can see all of the additional ribbing above. I verified the number and pic with getrag. However, all they did was stiffen the case. Internals are the same.
Nicely done! I couldn't have broke it better myself. :lildevil:
1 - 11 of 11 Posts
