Not really. The PCM has not been hacked, and there is very, very little aftermarket support for our cars. Forget about cutesy air filters, "CAI" installs (it already has a good one), cutesy spark plugs or so-called "chips".
Which car do you own - a SLS or STS ? The 275 hp 3.11 final drive SLS is a good, economical highway cruiser. The 300 hp 3.71 STS is the "performance" model with active magnetic ride control suspension.
Either can get a slight power gain up at redline shift points using the 14150 CORSA catback exhaust - about $1450. Look at the before and after dyno runs in the thread titled "Vroom, vroom". Google "cadillac forums seville vroom vroom".
Is there anything(performance mods) that can be done to 04' sevilles
NOPE -
Cadillac picked ALL of the "low-hanging-fruit" when they built the Northstar motor -
well actually there is ONE thing that has been PROVEN to increase horsepower - SLIGHTLY -
but the increase is at redline - during WOT - Wide Open Throttle - on the STS model -
the CORSA exhaust - $1500 for MAYBE 15 horsepower -
BUT - the SOUND that the Corsa system produces is worth the price of admission -
Okay thanks, and it is an SLS. Also when I got it I had my mechanic switch the magnetic RC to a regular suspension setup do you know how to get rid of the service stability control message in the instrument cluster.
the 2004 Seville only came as an SLS model -
and the SLS model never had MagnaRide -
SO - something doesn't add up -
the SERVICE STABILITY SYSTEM message is usually caused by a faulty Steering Wheel Position Sensor -
but - to be sure - check for DTC's - Diagnostic Trouble Codes - using the on-board scanner -
if you don't know how - go here -
post any codes you have -
ALONG WITH THEIR DEFINITIONS -
include whether they are C-Current or H-History -
for code definitions - go here -
here is a how-to video -
??? 2002 - 3 - 4 SLS does not have the F55 MRC suspension.
More info in my answer to your PM.
