1 - 8 of 8 Posts
2008 CTS Base
For some reason YouTube is recommending videos that y’all about the PCV valve in our V6 engines. They say the clogging and small opening is part of the reason for timing chain issues and oil consumption.
Is this true? If so, do I need to modify the valve? Did GM make a bigger one for the 2014 and newer motors? Do I just buy the updated one? Sorry if this is already a topic.
2008 SRX4 & 2010 CTS4 sedan / Non-Cadillacs: 2018 Audi Q5, 2012 Chev Cruze LT
The great debate.
Pull it. If it's clogged, do the mod. I modified mine a couple of years ago but mine was bone dry at the time and likely didn't need it. I've pulled mine a few times and there has been more oil over time but, frankly, less since I changed the cam cover gaskets and done some general tightening up of hoses.
It is not a cure-all IMO.
**2014 CTS4 Sport Wagon-Luxury**
I believe that GM made a modification to the PCV orifice prior to 2014...had yours been replaced or is this on a different car than your 2008 Bast CTS???...
good luck
Bill
2008 CTS Base
Discussion Starter #4 (Edited)
The great debate.
How does it look
2008 CTS Base
good luck
Bill
It’s for the CTS. Not replaced,never been worked on.
2008 CTS Base
Well, it's not clogged for sure. I would leave it alone.
I really appreciate ya northern. You are very quick to help and have a lot of knowledge. I’ve never been a good mechanic, but I love cars and detailing. The minor maintenance I’ve been doing recently really is satisfying and I want to learn more.
This CTS was my grandmother’s. She chose for me to have it because I would care for it the best, even though I didn’t need a 3rd car.
'12 CTS Performance Sports Wagon AWD
My 2012 with LFX has bigger holes and has no oil usage.
My 2009 had about a quart every 800 miles.. Still was 800 miles after I opened up the holes. Was told if I had installed a catch can it would have taken care of the oil usage problem after the holes were enlarged.
1 - 8 of 8 Posts
