i have a slight oil leak on rear valve cover. i thought the pcv system resulted in a slightly negative vacuum in valve cover? should this help minor oil leaks from leaky gaskets? my pcv valve does rattle. i assume the hose to TB is open and does suck air? maybe i should check it.
