My driver's side zone seems to work fine but the passenger side just blows cold. Any ideas of how to diagnose? I imagine it could be a, fuse, relay, sensor, the actuator or the heater core (if there is a separate one for the passenger side).
I know it doesn't help you, but mine works perfectly. We haven't had anything below about 14 deg F (-10 deg C) yet this winter, but it's coming, and I'll be in good shape when it does. My heated seat will absolutely roast my butt after a few minutes. FWIW, every car has it's quirks re HVAC performance, IMHO.Is it just me or have blend doors been failing with regularity on most Cadillacs since the early 2000's? My previous car, a 2008 CTS had the issue, and in researching it I found lots more.
I wonder if the search term Cadillac+blend door would result in millions of hits on Google LOL
Absolutely. HVAC in the Jaguar X-type is a total mess, and there is a similar procedure (temp all the way to min, then to max, then change blower setting) to try and reset it for normal operation, which doesn't always work.FWIW, every car has it's quirks re HVAC performance, IMHO.
O I don't have the issue with my current car, but it appears that most Cadillac models in the last fifteen years have a higher than normal failure rate of their dual zone HVAC, and often it's the blend door actuator that causes it. It shouldn't take a generation for Cadillac to source a reliable component manufacturer.I know it doesn't help you, but mine works perfectly. We haven't had anything below about 14 deg F (-10 deg C) yet this winter, but it's coming, and I'll be in good shape when it does. My heated seat will absolutely roast my butt after a few minutes. FWIW, every car has it's quirks re HVAC performance, IMHO.
It's kind of funny, the blend door in my Mom's 2000 Nissan Maxima (that she bought new) just failed this winter (stuck on hot, thankfully for now). I'd say 20½ years was a pretty good run for the thing!O I don't have the issue with my current car, but it appears that most Cadillac models in the last fifteen years have a higher than normal failure rate of their dual zone HVAC, and often it's the blend door actuator that causes it. It shouldn't take a generation for Cadillac to source a reliable component manufacturer.
My X-type was trouble-free for 13 years. Actually was one of the most reliable cars I've owned.HVAC in the Jaguar X-type is a total mess
What year was your X-type?My X-type was trouble-free for 13 years. Actually was one of the most reliable cars I've owned.
My ATS has been in service for HVAC 3 times in 2 years.
Actually, none of that.What year was your X-type? (clipped message)...
Wow, sounds like you were pretty lucky, and not just at the end. That driveshaft replacement under warranty might have nipped any vibration issues (very common) in the bud.Actually, none of that.
2003 2.5 5 spd m/t
2 repairs under warranty, window regulator (broken plastic bit) and driveshaft replaced for a vibration.
Paid repairs beyond 4y/50k: a $15 PCV hose split around 70k, and rear control arms around 100k. A couple wheel bearings some time past that.
I won't count pads/rotors (never a caliper!), tires, and swaybar links/bushings (which are consumables with our roads!) a few times, I was likely responsible for their early demise anyways LOL!
It had gotten pretty rusty in structural areas (my fault) and I traded it in after 13 years and 135,000 mi.
I will say this though, I'm damn glad I was able to trade for my ATS on the spot.
The a/c died (Comp. clutch) while I was car shopping. Didn't matter anymore.
A few weeks later on the day I went to look at my ATS, the Jag lost cruise and abs on the highway, check eng. light came on too. 5-10 miles later it went into limp mode at a stoplight on a 6-lane city street. In downpouring rain. Restart got it going and got me to the dealership. They started it, saw the light show on the dash, and gave me a $500 appraisal which I took - didn't want to drive it home!
Talk about timing!!
