'99 Eldorado
Hey folks,
I was changing my oil the other day and took a look at my transmission since I knew there was a leak. It looks like my drivers side axle seal is clean, no leaks, which I know there are a lot of problems with that side. My PASSENGER side axle seal, on the other hand, is leaking pretty bad. Just a drop here and there, but when I park the cR after it being in reverse, there’s a good 7-10 drops that come out of it.
I’m curious if anyone has any experience with this and if there are any common issues I should know about? I know the bearings are a big issue on the drivers side, but with this being the passenger side, is it also a problem or will a simple replacement gasket fix the leak? Thanks!
02 Seville, 04 SRX
You can repack the half axle or you can replace it. It's pretty easy to replace the passenger side one. Drive side is a little harder because of how the transmission sits.
I think he's talking leaking ATF, not axle grease.
