The SDM (airbag module) recall should not apply to an '06.
It also, sadly, doesn't turn on a warning indicator. The problem is that it can set off the bags on power up.
I haven't read CTS specific information but I am sure they are using the new PPS or "Passenger Presence System" that GM is using on lots of new cars.
There is actually a sensor in the seat that tells the module if someone is "heavy" enough to withstand deployment of the airbags. It also checks to see how far forward their seat is and if they are wearing their seat belt or not.
I have seen even smaller adults not be able to activate the PPS system.
I can't get to my service information right now, so I can't look up the details.
There should be some information in the owner's manual on this system.
Oops, here it is... I just got back in.
Inflatable Restraint Passenger Presence System
The passenger presence system (PPS) is used to monitor the pressure profile of an occupant on the front outboard passenger seat and communicate the status to the sensing and diagnostic module (SDM) whether to enable or suppress the deployment of the I/P module. The PPS consist of an electronic control module and sensor mat assembly attach to the bottom seat cushion, wiring harness, and PASSENGER AIR BAG ON/OFF indicators. The PPS measures the weight of the occupant sitting in the front passenger seat as a pressure change. If the pressure from the occupant's weight is less than a specified value, the PPS module will send a suppress signal to the SDM to disable the I/P module. If the pressure from the occupant's weight is higher than a specified value, the PPS module will send an enable signal to the SDM to enable the I/P module. The PPS module will notify the customer of the enable/disable status by turning on one of the PASSENGER AIR BAG ON/OFF indicators located on the rearview mirror. The PPS monitors itself for faults and will set diagnostic trouble codes (DTC's) if a fault is detected. The PPS will also notify the SDM of a fault. The SDM will respond by requesting the instrument panel cluster (IPC) to turn the AIR BAG indicator ON.
