2007 Thunder Gray CTS-V
I need some suspension bushings. Really hard to find a source for them. I can buy some Urethane parts, but they require greasing, so I was looking for rubber replacements. Not like the old days when you could get all the suspension parts for acar.
05 Stealth Gray V
No doubt about that. The whole "replace the control arm instead of the ball joint" thing is a drag. The starter solenoid is another unbelievably difficult part to source.
Try buying a stock transmission mount for this car....and forget stock replacement catalytic converters!
Don't get me started....
Yep. Nalley GMC has a new #1 customer at the moment. Just bought two rear LCA's about $200 ea. The adj bolt was rusted into the sleeve, so I will need to saw it out.
Speaking of starter solenoids, the Metripack connector is shot on my wiring harness. Anyone know if a new pigtail can be had so I can splice it in a new connector? Am I making a bad assumption that the starter is a pretty standard one or did Cadillac make a special one just for the -V?
The parts source I posted above showed a new OEM carrier bearing for the driveshaft. Don't know if anyone had tried to use a replacement like that. My 07 had a new OEM driveshaft when I bought it, and interestingly a new OEM trans mount The part numberr sticker was still on it!!!
