1 - 10 of 10 Posts
2006 CTS-V
Hello and apologies in advance for the laziness of the first question:
Can someone please provide the OEM part numbers for the front & rear brake pads & rotors, as well as front and rear shocks.
Second question, can you recommend the most economical online vendor to provide the parts above in Canada?
Thanks in advance....
Premium Member
2005 CTS-V
89047725 = Front Brake Pads; 89047744 = Rear Brake Pads; 25750248 = Front Brake Rotor; 25750257 = Rear Brake Rotor; 19150079 = Front Shock; 25752922 = Rear Shock.
2006 CTS-V
Perfect. Thank you !
Hi Darkman - can you verify if the front brake pad number should be 89047725?
'05 CTS-V
For future reference, www.cadillacfaq.com is a good resource for OEM part numbers.
Now, with that said, is there a specific reason you want the OEM pads and rotors? There are any number of aftermarket options that are more affordable and work as well (if not better).
2006 CTS-V
Hello everyone,
Did my pads and rotors today, and just before taking it for a test drive desk, decided to double check the calliper pins and when I looked on the passengers side I saw brake fluid leaking from the brake line to rigid pipe transition just before the calliper. Reached up to see if it was a connector issues and the line snapped in half.
WTF?!
Luckily local parts store had one in stock. So my question is should I replace the drivers side now as well assuming it will be close to failure? What about the rear?
Premium Member
2005 CTS-V
I would replace them all. There was a recall on the CTS, which did not cover the CTS-V but arguably should have. The recall was limited to the front, so whether you want to replace the rears could depend on what they look like compared to the fronts.
2004 CTS-V, Black, Borla exhaust
I know this is an older thread, but are these the ACD part numbers for 2004 CTSV as well?
'05 CTS-V
Yes, those part numbers are correct for all of the 1st gen CTS-Vs. I would ask you the same question I asked Juggernaut - is there a specific reason you want the OEM pads and rotors? There are any number of aftermarket options (including from ACDelco) that are more affordable and work as well (if not better).
Well, like many of us, there is so much good information on this forum that after reading what I can, it looked like OEM is the way to go. But, what other AC Delco pads are out there i could use that may be cheaper and work better?
1 - 10 of 10 Posts
