95 sedan deville
Does anybody know the correct part name for the pump that levels the cars ride,cause on my 95 deville the pump does not turn on at all,and i think it is bad,and i want to look up some prices for it,i just dont know the correct name for it...thanks guys
Fuse
Cut off switch
Wires
Relay
These are just a few of the parts that deal with the Air Ride Air Pump
Not sure of the true tech name for it hmm let me look it up.
Air Ride Compressor
That is the Tech name for it. I found mine worked fine but the cut off switch/relay in the back was bad. Good Luck
BTW the GM Mini Vans like the Transports, APVs, and like models had the same pump along with several of their car models.
95 sedan deville
the switch/elay u are talking about,was that the one located behind the back seats,and can u actually tell if they are bad or u just switched it out to try if it worked..thanks...also where is that cut off switch u mention located at...
95 sedan deville
thanks ranger, hopefully its not the compresor,i checked the fuse,relay and they seem to be in good shape,i have to check the wiring and that cut-off switch that hawkmc mentioned, then go check the wiring...
