1 - 1 of 1 Posts
2006 Escalade
Hey guys, my warrenty is up in 4000kms so I wanted to get these leaks that have sprung up in the past month fixed before its too late. I had the caddy in the shop of other leaks a month ago, I can't believe they didnt see these coming...hard to imagine that both sides have happened in the same 1 month span. THis is along with a transfercase seal leak I found, prob has nothing to do with them pulling the tranny last month to repair a pump seal leak. Anywho, I don't know what part I am looking at thats leaking and was hoping someone could ID it for me. In the first pic you see the drivers side and 2nd pic is the pass sides of the front diff. the passenger side pic sure looks like a seal on the diff but the drivers side seems to be coming from between the 2 clog shaped parts that are bolted together which then go the CV joint. What are these clog looking parts called and could there be a leak in one or both? or would you say its the diff seal on each side? Thanks for your input.
1 - 1 of 1 Posts
