05 CTS-V
Has anyone tried to connect the pacesetter headers to a pre-bent X-pipe? Was wondering if it would be worth my time to purchase the X-pipe w/ cats pre-bent or have a shop do some custom work.
2004 Raven Black CTS-V
I'm not fully understanding your question....but pacesetter makes adapters to bolt the headers to a stock exhaust (or replacement). Then you could keep your resonator or replace it with an x-pipe.
05 CTS-V
I apologize for the lack of clarity, but my question was directed more towards will an aftermarket x-pipe bolt up the the pacesetters. I am planning on doing a high flow cat setup at the same time, and was not sure if I should just have a shop do some custom work or look for a prebent setup
Are you running stock exhaust? If so, get the pacesetters and the slip-on flange connectors. They will allow the headers to bolt up to stock exhaust. Then get a universal x-pipe and swap it in place of the resonator (do a search on here and you will probably find a few options). If you want to run cats, you can grab a couple high flow cats and weld them in wherever you want...probably between the headers and x-pipe.
