1 - 20 of 35 Posts
02 Seville, 04 SRX (sold), 96 Eldorado (sold), 99 DeVille (sold)
I am debating on getting the head gasket job done. I have had intermittent P0741 without P1860. Does this mean that the whole torque converter needs to get replaced? If so, how much is the part usually? I would have this done when the cradle is out of the car.
Could be the TC, or seals inside the transmission. No way to tell, so they both need to be done together.
Ranger, you wouldn't know off the top of your head the approximate cost of the solenoid would you? Rockauto has a Control Solenoid for under $30, can it be that cheap?
The solenoid was about $65 GM retail. The GM shop labor to replace the solenoid only is 10 hours.
To replace the converter, seals, and solenoid is about 14 hours, not including parts.
with the trans sitting on the ground -
figure around $1200 to $1500 to tear it down -
replace the seal and torque converter -
Discussion Starter #8
Basscatt, you are saying that $1200 to $1500 would be the whole job? The engine and transmission will already be out of the car to address the head gaskets, I was thinking that the transmission portion would be very small (price wise) since everything is out of the car.
no -
that would be the cost to repair the trans -
and includes a new torque converter -
it does NOT include removing the trans from the car -
nor re-installing the trans -
2010 DTS
Yeah, we call it the $20 part, buried $2000 deep in the trans.
Too many...
What is the seal in question? And how could it be thousands in labor to get to a part on a transmission already loose? That doesn't add up. A loose transmission can be fully rebuilt in well under 10 hours. You guys throw out absurd numbers sometimes.
do a little more research - and post YOUR findings -
please include company names and contact information -
willing to replace the seal and torque converter in question -
2010 DTS
The thousand dollar numbers are for when the drivetrain must be dropped.
I have no clue what it would cost if the trans is already out, but I doubt it would be anywhere near that, but like Bass said, get some estimates.
Discussion Starter #14
What parts need to be replaced specifically? Is it just the seal or does the Transmission Control Solenoid get replaced along with it?
2010 DTS
The seal needs to be replaced. GM recommends replacing the TC as well and while it's down, can't hurt to replace the solenoid.
If you read the link in post #3 you should have noticed this.
Replace the Torque Converter when servicing a vehicle with this condition.
The Viscous Coupler has an extremely high failure rate when it is allowed to slip out of spec.
Discussion Starter #16
I get it. Needs a new torque converter. I'm reading through all the threads where people have P0741 and just live with it. Since we know it is the torque converter, can I just live with it or does it mean that I will soon see complete transmission failure? Also, going 50 and then tapping the brake the RPMs don't ever increase. I don't know if this information is relevant or not.
'96 STS
Had the solenoid replaced in my 1996 STS several years ago at a Cadillac dealership in Victoria BC. Meant pulling the engine/trans, repair and re-install...$3000.00 ! Trouble free and 70.000 miles later. Still think it was worth it.....love the car !
IF you are replacing the seal -
GM recommends replacing the torque converter at the same time -
P0741 - by itself - means there is a worn seal - deep in the trans -
that is preventing the torque converter clutch from going into LOCK-UP -
correct -
the ONLY problems with this condition is that you will -
1) automatically fail an emissions test -
2) loose 2 or 3 mpg at highway speeds -
YES -
if you are not subjected to emissions testing/inspections -
and you don't care about a couple MPG's at highway speeds -
NO -
the condition will not adversely affect the longevity of the trans - at all -
as you noted above - MANY choose to "live" with the condition - for years - forever -
correct - because your converter doesn't go into LOCK-UP -
if the converter was going into LOCK-UP -
tapping the brake takes it out of lock-up -
and the rpm would increase by 200 to 300 rpm -
this may help explain things -
imagine two electric fans - facing each other -
one fan is plugged into the electrical socket - and turned on -
this represents the engine-driven half of the torque converter -
the second fan WILL be turned by the airflow of the first fan -
the second "fan" within the torque converter -
is driven by trans fluid - instead of air -
and turns the transmission -
the second fan will not spin as fast as the first fan -
there is a slight loss of power -
EXACTLY what happens with the torque converter in the trans -
now imagine a couple sticks - sticking through the fan blades -
now - BOTH fans must spin at the same speed -
because they are LOCKED-UP - forced to spin at the same speed -
this is the theory of how LOCK-UP works -
the lock-up solenoid is replaceable without pulling the trans -
............ with about 8 hours of backbreaking disassembly, microsurgery, reassembly - through a 1" wide space provided by removing everything on the rear (driver's) end of the engine and transmission and loosening the transmission side cover.
Videos in Cadillac Tech Tips.
2010 DTS
I have and have had the P0741 code for years now. Constantly clearing the code is a PITA, but other than that (and a mile or two loss in MPG) I don't even notice it and do not expect any trans problems.
P.S.
Obviously, I'm not subjected to emissions testing.
1 - 20 of 35 Posts
