1 - 2 of 2 Posts
hello i got a question i got on my 95 caddy seville a code p056
i want to know what is the problem , do you know if i have to replace the sensor or the problem is the circuit
That's what you get to find out. You have to find the sensor and check the wiring connections. Loose or dirty connections can set the code or the sensor could have gone bad. The code only tells you the computer isn't getting the right (or any) signal from the sensor.
1 - 2 of 2 Posts
