1 - 20 of 25 Posts
P0449 error code any hint´s
I´ve got on my 07 escalade this error code (P0449), i reset the error code but it still comes up. Could i check something be myself or is it so difficult to give it to an dealer ?? I saw there may be an TSB for this, would be great to have this doc
thanks in advance from snoey bavaria
robert
ESCALADE
Re: P0449 error code any hint´s
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
This code can be caused by a loose or faulty gas cap.Look for cracks around the seal on cap.
thanks
the gas cap seem o.K. , i really want th check into the relay or sensor. do anyone know where i have to check in which part of my escalade is the
solenoid ??
Escalade
Hello..Did you get the problem fix?? I ma having the same issue
After the cap is replaced what else can be done? I ordered a new canister ..but reading this now I am not sure if that will make a difference
2007 Escalade, 2006 STS
It is the evap vent solenoid. Search the part on a parts website. It is located under the spare tire and it is pretty simple to switch out. Just pull off the 2 tubes and replace the old part with a new one. There is no liquid running through the part. I had the same problem and I was able to fix it in about an hour. Biggest pain is taking the spare tire off.
2010 Escalade ESV
I agree, GM trucks are known for this code and the replacement of the solenoid cures the problem in 99.9% of the. I had two Tahoes that had this code and the first time I replaced the fuel cap with no luck, then I checked all the hoses and connections with no luck. Next up I replaced the solenoid and cured the problem immediately. Second Tahoe I first replaced the solenoid and bingo, the problem was gone.
99 Escalade (sold) 03 Escalade EXT (sold) - 07 Escalade EXT
YUP. $45 shipped part. same thing happened to my truck. 20 mins to install.
2007 Escalade, 2005 CTS
Had this last October and for me it was the gas cap. Put a new one on cleared the code and it never came back.
07 Escalade EXT
I've got the same problem, will be swapping the solenoid out tonight after work. Naturally, last weekend when I went to lower the spare tire to get under there and see what the part looked like to verify i ordered the right one, the hoist seized about half way down. Not far enough to get the tire off the cable but too far to leave it so had to remove it and order its replacement as well. Thank god for amazon prime, the hoist was only $40 instead of the $150 everyone else wanted for it and the solenoid was only $20 something.
It'll be nice to able to use my remote start again.
08 EXT
There has been a redesign of this part and it is now $70 from AutoZone. And $95 at the dealer. Well in RI that is. And with the redesign, they changed the plug. Intern, you have to buy a converter plug as well. It cost $35 from the dealer, and $45 from AZ. RockAuto appears to not have the redsigned part yet. They still sell this part for $30.
08 EXT
Anyone have a part number for the evap vent solenoid? Just to be sure...is it this, the "purge valve solenoid"? :
http://contentinfo.autozone.com/znetcs/product-info/en/US/wl2/PV443/image/2/
Or is it this, the "canister vent valve solenoid"?
http://contentinfo.autozone.com/znetcs/product-info/en/US/wl2/PV449/image/4/
The purge solenoid is on the engine. The Canister Vent valve is in the rear, near the gas tank. The vent valve is the cause for this error code.
any pics on how it looks like? just in case?
I gotcha...
The valve itself...
The two assemblies beside each other.
The different vent on the end.
The converter plug
It's still relatively easy to change. You just have to route the vent tube, which is a little long the the OEM.
Escalade ESV
Hi, i have the same code so the only part i need is from autozone for $70 which is Duralast/Canister Vent Valve Solenoid
Part Number: PV449 anything else i need? also is this the newest one? thanks.
edit: on advance auto its for $32 ACDelco Evaporative Emission Canister Purge Solenoid Valve Part No. 214-1680 is this the old one?
Escalade ESV
can someone link me to correct part# the old one and the new one please..
08 EXT
You will also nee the plug as well, which they have at AZ for $45 P/N 1161. On Advance, the part cost $150. The purge solenoid is a different part.
I don't know the old P/N but the new one is~
Vent solenoid; 20995472
Pigtail; 19257603
Escalade ESV
my escalade has a line running from the compressor to the vent filter, the new soenoid does not have a place to connect this vaccum line. What did you all do about it?
1 - 20 of 25 Posts
